Old 03-06-2008, 09:23 AM   #27 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
I just found my spare lamp timer.
This one says it is rated for 15 amps! Most of the cheap-o lamp timers are only rated at a few hundred watts at most.
My engine block heater is 500 watts.
I am planning on now plugging: my block heater into an extension cord, that cord into the timer, and that timer into the KillaWatt.
That way I measure the combined electrical usage of the block heater and timer (yeah, I know the timer should use almost NONE, but I want to measure it anyways.)
Who can suggest how long I run the block heater timer for in the morning? The engine is a 2.2L 4 cylinder - and the car is parked in the driveway, not a garage.
Also, how much of the year does it make sense to run the block heater? Would it help in efficiency in the spring and fall too? Is there a certain temperature, above which, one stops using the block heater as an engine pre-heat?
-Ben
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
