Unit complete
Tight fit, but everything clears
I can't believe how underbuilt these honda pedal clusters are. With the added 5 lbs of force I decided it would be best to add some more welds to the the frame and hope it holds up in the long run. I'm not particularly happy with the way the whole cluster frame moves when the pedal is depressed. Using a lighter pedal spring may compensate.
Now I just have to get the car running...
