Originally Posted by aerohead
Is the source of EMF the 3-phase electric motor or high-voltage switching power supply? Does Gauss vary as the inverse-square of the distance from the source as other radiated energy devices?
I think if you half the distance it gets 4 times stronger, so if you get 10 times closer it goes up by hundreds. The motor and control systems would both have harmful emissions.
The car in question, the 1st Gen Insight, has a body almost all aluminum.
