09-28-2009, 11:44 PM
#109 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
[QUOTE=Tygen1;130503]
Originally Posted by orange4boy
The TCC lock is working well but not showing on my FE yet probably because I'm still learning to use it and tend to stay in gear longer than I would have before. Also there has been road work and such here. At least it will be simple to do A-B-A with this set up when I get the chance.
QUOTE]
This is why I couldn't justify taking mine any further, the risk vs. reward was minimal. I precieved the gain to be substantial because I was not in control of the locking, however the reality was I can only shift moments before the ECM would have and the net savings is minimal and definatly not greater than my normal variation in mpg, so I could never quantify it.
You guys really need to give the PLC controllers some thought, they will automate all this sillyness into simple comands and you'd only need one switch to bump up or down for upshifting or down shifting.
K, thought about it.. won't work for me. (Hydraulic transmission)
