Gallons aint gallons
I just wanted to check with the OP, are you sure you're getting a gallon for every gallon you're charged for.
Here in oz there were a few tests done on random service stations and a few were found to have pump which supplied just less than a litre for every litre the pumps said that it pumped.
Might be worth checking, some of those cheaper stations need to do everything they can to stay afloat.
