Old 10-02-2009, 10:36 AM   #31 (permalink)
SleeperRT
The PT - '02 Chrysler PT Cruiser Limited
The Dakota - '02 Dodge Dakota R/T
The vette - '80 Chevrolet Corvette L-82
The T/A - '79 Pontiac Firebird Trans Am WS6
Oh, side tidbit... In, I believe, 1985 they started mandating some ethanol be mixed into gas (formerly known as gasohol). Which is like 5-10% ethanol anyway. This has become our modern gas. As they use ethanol as an octane booster now.
Relevance... cars before this date ran traditional rubber which is eaten up by ethanol because it's very acidic compared to gas. Cars after this date ran synthetic rubber hoses which are not eaten up as bad. Your fuel pump is a rubber bladder (like a power brake booster). The older ones will, and most regular ones go out because this acidic property deteriorates them over time. BUT this isn't horrible because on metal it's great. After running gas for a long time all the small passages get plugged with gunk and need to be replaced, but ethanol will clean all that out. If you don't want to replace hoses and pumps all the time, make sure your fuel path is running things that can handle alchohol or gas.
