You're right. Smart knew people would question the safety of such a small car, which is why they made it so safe and made the safety cell visible from outside. As for a manual gearbox, I don't think it needs one (the lack of clutch pedal was why I bought it) but I do think it'd be better off with a 5 speed gearbox than the 3*2 speed it has. The lower gears are too close ratio and the higher gears are too far apart. It all stems from the car using a 3 speed gearbox and a 2 speed final drive. Still, it just means an extra gear change, in reality.
