Old 10-07-2009, 08:09 PM   #20 (permalink)
dwtaylorpdx
Originally Posted by micondie View Post
How high do you space the hood? Is it high enough to direct some of the air flow upward so it gets a head start flowing over the roof or is it just high enough to bleed off some of the high pressure air into the engine compartment?
Usually the rear edge of the hood is 1" higher. Much more and latches and such get hard to use. I also pull the gasket off the rear edge of the hood to really open up the gap.
Dave
