Old 10-05-2009, 06:47 PM   #11 (permalink)
micondie's Avatar
moby van - '03 Dodge Caravan SE
90 day: 19.74 mpg (US)
Originally Posted by dwtaylorpdx View Post
On a lot of sedan race cars we add spacers under the hood hinges to let the high pressure area in front of the firewall loose. It often ads 4 or 5 mph down the straightaway. Anybody tried it for mileage?
Dave
How high do you space the hood? Is it high enough to direct some of the air flow upward so it gets a head start flowing over the roof or is it just high enough to bleed off some of the high pressure air into the engine compartment?
Old 10-05-2009, 07:12 PM   #12 (permalink)
PSmodder lurker
Kamm extending spoiler
This thread has piqued my interest because I have been playing around with an extending Kamm-rear spoiler idea. The critical downstream rear angles could always benefit to a long-tail configuration. The idea is very similar to reconfigurable/extending airplane wing flaps. The move-able wing extend & become flush/fixed to the fastback surface & additional wingtips deploy downwards to clean up some side flow. I've considered these add. tips to deploy outside the rear light assembly but would compromise the safety equipment. The wingtips always could be made w/ clear polycarbonate to passed safety reqs. Lower speeds & parking maneuvers needs retracting the wings. 'Active' wing flap angles become too complicated.
Also another idea, a model specific (Prius 2010) rear wheel covers extend to very clean flows sharply detaching at the bottom & rear edges...
Old 10-05-2009, 10:01 PM   #13 (permalink)
pstrbrc's Avatar
OK, this is something I'm working on for my Escort. And one of the limitations that I have is that TOWMBO will not tolerate any public display of eccentricity.
So, a belly pan is acceptable, but a boat tail is not. Wheel discs are borderline acceptable, rear wheel pants are clearly not. So, I might get away with vg's, but...
So, my back glass is ~30* from horizontal, and a line from the back of the roof line to deck height at 14* says I need a 8"+ shelf attached.
What does the collective mind know about the +/- of rear window dust deflectors? I know, those are usually only for "wagon" backs, but a deflector with an included arc of 25* would certainly be a place to start. Yes, this would cause lift at high speeds, but at econ speeds, what would be the down side? Would a smooth deflector blade cause more drag than 8 vg's across the back edge?
Old 10-06-2009, 06:56 PM   #14 (permalink)
deflectors
What I've read about them is that the act of directing air towards the wake is good,but air separates off the back side of the deflector for a net drag increase overall.--------- simple flat plates extending straight back,which capture vortices along a quasi-Kamm profile have been demonstated to help,although you have the "length" issue.
landsailor (06-13-2011)
Old 10-06-2009, 10:58 PM   #15 (permalink)
90 day: 51.82 mpg (US)
Cd: "damned pressure bubble"... thanks for the laugh.
Old 10-07-2009, 12:33 PM   #16 (permalink)
PSmodder lurker
"Out damn bubble, out!" Seems to be common running joke 'round these parts...so has anyone done the obvious & 'attacked' it with something like this...
http://www.team-bhp.com/forum/attach...s-dsc02307.jpg
Looks like bug deflectors moved backyards but smoke tests & tuft testing would be interesting to see.
Old 10-07-2009, 01:19 PM   #17 (permalink)
chuckm's Avatar
Exploder - '02 Ford Explorer xlt
Rolla - '02 Toyota Corolla ce
90 day: 44.43 mpg (US)
I hope I'm not misunderstanding you... if I attached a short Kamm profile lip to the top of my rear windshield area, I might gain a little benefit?
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
Old 10-07-2009, 06:17 PM   #18 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Both Aerohead and Basjoos created air deflectors for their wipers. I'll let them eloborate on any gains. I tufted my car and noticed that the turbulent bubble on my car only extended a couple of inches past the arm of the wiper.
Also look here. This is a very good article on tufting the wiper area : http://autospeed.com/cms/title_Silen...5/article.html
Old 10-07-2009, 06:31 PM   #19 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I'll let Aerohead answer this one.
I added a small lip spoiler to the edge of the roofline on Franks' car due to the fact that his back glass has such a steep angle. His car is almost like a hatchback with a trunk.
( I hope I understand your question. )
Old 10-07-2009, 08:09 PM   #20 (permalink)
Usually the rear edge of the hood is 1" higher. Much more and latches and such get hard to use. I also pull the gasket off the rear edge of the hood to really open up the gap.
Dave
drag, reattaching wake, shelf spoiler, spoilers
Aerodynamic Streamlining Template: Part-C aerohead Aerodynamics 777 09-14-2024 11:33 AM
Reducing notchback drag; New Ideas majestic Aerodynamics 16 09-15-2009 05:47 PM
BMW cooling duct fabrio. Aerodynamics 19 09-27-2008 04:48 PM
Are there any magic numbers? justpassntime Aerodynamics 32 09-10-2008 10:00 PM
Installment # 11, Part-4 Quotes aerohead Aerodynamics 0 07-02-2008 01:46 PM
