Originally Posted by dremd
AE340 does the same, it will even keep to motor turning if you downshift (either manually or electrically). however once you put it in neutral with the motor running, it is all over.
I think it's VSS and Vacuum. I've wondered the same...
I'll dig out the shop manual and see if I can figure out what mine does...
RH77
