Old 03-08-2008, 05:02 PM   #9 (permalink)
Chris D.
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Chris: check AndrewJ's Civic CX aero mods thread - he used some thin plastic to form his wheel skirts.
I'd like to see someone do some foam sculpting to make a set of glass skirts though. Mostly because that's what I'm thinking of doing for my partial Kamm back this summer, and I'd like to learn from someone else's mistakes rather than my own .
I second Frank's comment: lose the bug deflector. If it's there to protect the paint, I'd put on some of that plastic film instead.
EDIT: whoops, I see you've already taken it off.
I've made lots of stuff doing foam/fiberglass work..
I use expansion foam, let it setup and shave it as i see fit,
then I lay glass on it..
then you pour gasoline inside and it eats away all the foam..
watch what a drop of gasoline does to styrofoam..
