I desided to hit home depot and see what I could come up with..
I figured on this flat steel thats easy to bend into shape..
I'm going to make L brackets to mount to the inner wheel wells and drill two holes.. one to mount them and one for mounting the skirt..
I have bolts that i'll weld to the frame and use washers and lock washers with wingnuts for easy removal from the backside..
I'm wondering how to cover these? fiberglass? any ideas?
![Confused](/forum/images/smilies/confused.gif)
My wheels and tires tuck if I were to slam the vehicle down to the ground..
but the bottom needs to kick out slightly to make room for the wheel/tire..
I taped some cardboard onto the tire to use as my gap..
are my angles looking ok or are they too steep?
I'm going to weld the frame together and use some wire to make an outter frame to fit snug..
If you have any ideas what to use to cover this, kick em my way..
I'm taking my time and in no rush
heres my mockup.
be kind, I've never made these
Top view
back view..
any constructive criticism is truely appreciated..
![Thumbs up](/forum/images/smilies/grinning-smiley-003.gif)
Thanks in advance
