Old 03-09-2008, 01:05 AM   #80 (permalink)
darkdan
Window Tinting Pimp
Originally Posted by RH77 View Post
Any advantage over good ol' Seafoam?
RH77
Plenty, Seafoam is pale oil (light oil), naptha, and rubbing alcohol in a 6:3:1 ratio.
It does not have the property viscosity for good lubrication in an engine.
It does not have the property cleaning properties. It cannot safely suspend cleaned contaminants.
It is not ecofriendly (auto-rx is NON-TOXIC!!!!).
Seafoam has it's uses (hot motor, through a vacuum hose), but in the motor and in the gas tank are not the proper uses.
There is NOTHING like auto-rx.com available anywhere else in any other form.
Check out the auto-rx forums for hundreds of happy users:
http://auto-rx.activeboard.com/
