Old 03-04-2008, 08:46 PM   #71 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
I'm done
"Judge a person by their questions rather than their answers."
Old 03-04-2008, 09:07 PM   #72 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I'll get on it soon, Want to make sure I give everyone a fair shake.
Old 03-04-2008, 11:28 PM   #73 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
I'm working on it as well...
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 03-04-2008, 11:37 PM   #74 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
I won't be voting, as I have a dog in this fight, so to speak.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 03-06-2008, 07:56 PM   #75 (permalink)
XFi
Driving NOW
XFi's Avatar
Now - '07 Hyundai Accent GS
Xspire - '97 Ford Aspire
90 day: 47.9 mpg (US)
I have recieved votes from only MetroMPG and Lazarus so far...Still waiting for the others. SVOboy and RH77???
I'm sorry I missed your Moderator Status AndrewJ, but you are in the contest just like TomO so not eligible to vote on the contest.
Also, Mike is eligible to vote...anyone else I missed?
XFi
Old 03-08-2008, 08:34 PM   #76 (permalink)
Window Tinting Pimp
If the engine has any significant amount of miles on it you should use www.auto-rx.com
Auto-rx will safely and effectively clean the ring packs for less blow-by. Which means better compression. Which means better efficiency. In turn, that increases gas mileage.
Old 03-08-2008, 10:28 PM   #77 (permalink)
Dartmouth 2010
SVOboy's Avatar
I've heard good things about auto-rx as well.
Welcome to the site, darkdan!
Old 03-09-2008, 12:48 AM   #78 (permalink)
Window Tinting Pimp
Thanks, I drive a 94 Ford Aspire! I'll have to introduce myself later.
Old 03-09-2008, 12:53 AM   #79 (permalink)
Depends on the Day
RH77's Avatar
Sports Cars
Any advantage over good ol' Seafoam?
RH77
_
_
Old 03-09-2008, 01:05 AM   #80 (permalink)
Window Tinting Pimp
RH77
Plenty, Seafoam is pale oil (light oil), naptha, and rubbing alcohol in a 6:3:1 ratio.
It does not have the property viscosity for good lubrication in an engine.
It does not have the property cleaning properties. It cannot safely suspend cleaned contaminants.
It is not ecofriendly (auto-rx is NON-TOXIC!!!!).
Seafoam has it's uses (hot motor, through a vacuum hose), but in the motor and in the gas tank are not the proper uses.
There is NOTHING like auto-rx.com available anywhere else in any other form.
Check out the auto-rx forums for hundreds of happy users:
http://auto-rx.activeboard.com/
