O crap... so should I use anything special to get aluminum oxide off of the surfaces I used the pad on? How certain can I bet that the pad I used contains aluminum oxide? I dont remember if it was an actual scotch brand pad or what - it was just sitting around my father's shop loose. It was brand new, but no packaging and I don't remember what the "watermark" on it said. I suppose it will be alright if I wash it off really well with water or a vinegar solution (from reading what the google machine tells me about aluminum oxide).
