Old 10-17-2009, 02:58 AM   #123 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Important note for transmission modders: Some transmissions use a pwm signal to give different duty cycles to the TCC. This allows some slippage. I found an article that explains how to do it properly although you will have to modify it to get the on demand lock up:
A604 transmission: Chrysler, Plymouth, and Dodge Four-Speed Automatic Transmission Torque Converter Disabling(not really disabling but disabling the slip)
Adding a manual switch will actually reduce wear on your TCC and reduce heat build up in your transmission.
Christ, is this what Cara has?
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Last edited by orange4boy; 10-17-2009 at 04:40 PM.. Reason: removed incorrect statement r.e. solenoids
