Originally Posted by Christ
I based that on the idea that you were getting grinding while trying to "clutchless shift" with the ICE still installed.
If this is not the case, I'm incorrect in the above.
Did you change the transaxle fluid?
I changed the fluid just a few thousand ICE miles ago with Amsoil Synchromesh so I didn't think it needed to be changed again. The transmission wouldn't grind before with the ICE, it just refused to get in gear. Slides right in now!
