Old 03-11-2008, 12:35 AM   #18 (permalink)
Chris D.
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
I've hit a snag in the road here..
My orignal setup wouldnt work because the brackets wouldn't have anything to attach to..
I thought the inside lip was continious all the way around for an inch deep, but once i removed the splash sheild, my assumption left me having to reconfigure things..
so insted of the double setup I was going for, i ended up having to go back to an orignal setup of only having one leg going up..
This is how I was going to attach the skirt orignally, but I came up on wheel/tire travel conflict even after trimming the bolt and threading it..
I drilled through the steel and tacked a bolt through it for an attachment point.
heres the bottom edge contouring the bedside..
(rear)
(front)
so after ditchign the upper wingnut idea, I thought, Why do I need to fully remove it?
So off I went to home depot (less than a block away) and I came up with this idea..
With that problem solved I've hit somewhat of a stumpped state..
I dont know how to frame the outside edge..
So I tacked some wire to see how well it would work..
its.. o...k.. but i'm not happy with it intirely..
I was running out of light, so I packed it in.
How should I finish this? I've got mental constipation here..
