Old 10-28-2009, 12:56 PM   #267 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 50.97 mpg (US)
Does the fact that Basjoos has installed inner and outer side skirts (pontoon style) between the front and back tires and a totally smooth belly pan allow him to keep more airflow under the car? Would this allow him to cheat the 4 degree limit on the bottom of the boat tail? If so, this would be helpful for a daily driven vehicle that has to negotiate steep driveways.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
