Old 10-31-2009, 12:02 AM   #11 (permalink)
dwtaylorpdx
Ford had the spec in the manual right at the pressure rating of the tires, then you add the heat buildup and the pressure went over the line. And they were only a 4 ply rated tire with two real plys. I got to look at a set once, you could wad the tire up with your bare hands....
Dave
If it has a motor its worth playing with.......
