Thanks to getting caught in the worst blizzard around here in thirty years last Friday, I had to drive about 50 miles at my best spot - 1000 RPM in top (0.73:1 overdrive) gear. As a result of that segment I had an exemplary tank MPG. 2 MPG over normal winter mileage.
Tas:
It is good living a few years in the town where your engine was built. If you know the right guys...
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
