Old 03-12-2008, 12:14 AM   #3 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
When you say it almost didn't start, do you mean it cranked over and over but didn't catch? Or was it a problem of not cranking, or cranking very slowly?
In either case, I'd be reluctant to be shutting the engine off until you've got the root problem sorted out.
Also - you're aware that you've only got about 2 brake applications before your power assist is depleted, and then it takes a LOT more pedal effort.
