Old 11-12-2009, 04:59 PM   #42 (permalink)
Frank Lee
^You got it!
Even worse are the ones that use cheater pipes on 3/4" drive rachet wrenches to tighten oil drain plugs. I have had to weld big hex nuts on them bastids in order to get em off!
What you said: It pretty much just has to be tight enough to not leak and not fall off. They ain't dang lug nuts.
