Originally Posted by Christ
Should be a pretty good indication that it's not what it's "cracked up" to be.
You might be right.
I was reading on the BITOG forum about oil additive.
There is a good approval for MMO and AutoRX when used as cleaning formulation. You have to be careful since MMO might remove too much gunk and clog the oil filter reducing the oil pressure. Probably not a bad idea to use it
close to an oil change.
Not much information about Cermax or Autocerm.
Some users instead seems to be very happy with RSV and Cermat. It is very early to say. Before using these I would do a cleaning phase first.
I wouldn't use (this is just my opinion) anything with teflon or eccess of zinc.
This for oil additive.
For fuel, how about the old acetone/xylene/GT2 formulation?
