Old 11-20-2009, 11:55 PM   #12 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Bottom has minimal airflow, I'd worry more about keeping the top attached. 15* may do it for you, though.
Best to set up a test bed type of mod, that you can tweak and test, rather than going all out on the first iteration, just for this type of question.
I do think that 28* on the bottom is way too steep to even think that airflow will stay attached, so it might be OK to break cleanly, rather than try to keep attached flow. I assume the front will have a lowered stagnation point, so there will be less than normal airflow under the car as well, correct?
