Carlos -
Try 2 quarts of Kerosene... then again, you should also check to make sure there is anything in your engine making it "less than new" in it's current state. Kerosene can damage things... LOL.
I've put tranny fluid in engines when they're really coked up, run it for 100 miles on the highway and through town, then change the oil... usually comes out blacker than black holes, thick and sooty. Afterward, I check the new oil for evidence of buildup and gunk every couple hundred miles. If it's clean, we're good.
MMO is basically trans fliud without additives, and it smells sort of minty. It's gotta be good, because it smells good. It will also "burn out" of your oil within about 1000 miles, so you'll want to check your oil often.
