Originally Posted by MPaulHolmes
Jack is definitely the man with the plan from Uzbekistan! I hope you post pictures of your process. It sounds like it's going to be awesome!
I've never tried bronze. Would that work OK? Is there a problem with the reduced electrical conductivity?
What voltage level? Current level? Good luck!!! ya! I would be interested in hearing how the IGBT paralleling goes for you.
I will not be able to go beyond 160VDC but I'm planing on 1KW or 1.2KW for all the "necessary" headroom.
This dual IGBT modules are HUGE and are 1LB each.
Horacio
