Thread: downshifting?
Old 03-13-2008, 08:27 PM   #6 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
I can set up your FE banners if you don't figure it out.
As far as downshifting - I wouldn't worry about it too much as a fuel saving technique. Rick's right about fuel cutoff, but it's much less efficient than coasting in N with the engine idling. The only time I'd do it is down some long, steep grades to descend where you need to keep your speed in check.
Generally, the most efficient way to slow down, from best to worst:
- in neutral, engine off
- in neutral, engine on
- in gear, engine braking
- regular brake
