Old 11-24-2009, 10:30 PM   #25 (permalink)
ECONORAM
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
motor mount fix
Originally Posted by Sean T. View Post
I have been on this site a while and haven't posted lately, but it is summer now so I'll have quite a bit of free time. I have a 1997 Ford Taurus and need some ideas for making it aerodynamic.
I would like to make an underbody shield, but I have read that my car is an "underbreather" so I'm afraid that a shield will cause my engine to overheat.
I know I want to do something with my mirrors, but AFAIK there aren't any aftermarket mirrors available that fit my car. I absolutely will NOT survive on the road without mirrors, so removing them is out of the question. Perhaps there is some kind of cone I could attch to it to decrease the front surface area?
I want to do something with the front of the car, but I don't know how to attch it, because I don't want to damage the paint, and I would like ti to be removable. I go SCCA solo races sometimes so It would get wrecked if it was permanent.
I also want to do some kind of wheel skirts or something, but my car is narrow at the bottom so the wheel sticks out a lot, so a flat skirt will not work unless it's just like the top 5 inches. And, how do I make wheel skirts on the front? Is that possible?
I would also like to make some kind of shield to cover the wiper blades, but I'm not sure how something like that would work.
I also want to remove my radio antenna, but I use the radio everyday. Is there a way to run a wire to the sheet metal or something so I can still recieve a signal?
Here is some pics of my car so you can get an idea of what I have to work with:
Sean, I had a 2004 Taurus SE for a while, and I got high 20s on the highway (even 30 once). I replaced the factory muffler with a Flowmaster Delta 40 and put Royal Purple in the crankcase. As I understand it, if you have the Vulcan engine, you can replace the original rocker arms with some that are slightly longer (1.7 ratio vs factory 1.6), and get some much needed ummph. I also bought a 3 ft length of chain and wrapped it around the front motor mount and subframe, so it could barely move. I bolted the chain ends together. This didn't produce any power, but it does keep the engine from rocking when you hit the throttle. It feels like adding a few hp though. Barely noticeable in the cabin. I am sorry I cannot remember the size, but I think I was able to shove a 1/4" bolt through the links. Take a look at Taurus Car Club of America , the Taurus Car Club of America. They will have some links/DIYs for these.
[edit] found the link... http://taurusclub.com/forum/index.ph...1&#entry416131
This makes me miss my Taurus...
