Old 11-25-2009, 03:21 PM   #184 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Rick -
Lookup "one wire Vtec"... it's a ricer mod that allowed the use of Vtec systems when the ECU wasn't designed for it.
Basically, wire an MSD RPM switch in, and when you get to whatever your "pill" is set to, you get a closed circuit. I'm sure you could set it up the other way around, as well.
