Old 11-25-2009, 06:59 PM   #194 (permalink)
sawickm
ReVolt Enthusiast
Adam,
In order to use the controller as a charger, you would need to rewire the battery from the battery side to the motor side, you would then need to apply some kind of DC power to the battery side of the controller. This would require some large contactors to be able to switch back and fourth.
The controller outputs are BM+, B-, M-, what do you mean by re-wiring the batteries and motor? Do you mean isolate the batteries from the motor using larger contactors? Does that mean you could not share the busbars of the controller between the motor and charger?
A better idea, I think, to keep things cheep would to use a power stage that is only 1/5 of the drive controller. This would be 2 MOSFET/diode pairs, capable of 50A.
Could a separate charger PCB containing the (MOSFETs/diodes/charger controller) bolt on to the Revolt’s busbars, heatsink, and use the same enclosure?
-Mark
