Originally Posted by RobertSmalls
You mentioned somewhere that you've insulated your catalytic converter to keep underhood temps down. What kind of insulation did you use?
Hi Robert,
The cat is surrounded with fiber glass batting. The same stuff that is used for thermal insulation in houses. Obviously, there is no paper backing, just the glass, which has a melt point of about 2000°F. Steel melts around 2500°F or so and starts to glow dull red about 1500°F or so.
So the glass *should* be able to take the heat from the cat.
Jim.
