Woohoo - another project under way.
(You should post a link at the end of your mother lode EV parts thread directing people here.)
Adapter plate is easy. You can make one with hand tools if you get a piece of aluminum plate.
I've also seen some conversions cleverly slice the end of the ICE block off, and use that as their adapter plate!
The coupler is going to be a bit harder to do.
Remind us again what your performance/range goals are?
