Originally Posted by SVOboy
Here's a question for you innovative folks.
The water pump belt I got from autozone is too big. What should I do? There are no others available.
Go buy a 370K5 (37") or 5PK935 (935mm) belt, or the nearest size that they *do* have.
Well, I'll have to poke around for that then. Also, I took a closer look at my exhaust, the S bend isn't going to happen, so I'm just gonna take off the second cat and run a pipe back. Only problem is the exhaust doesn't want to budge.
You mean you want to cut part #7 in half? But that's a $700 part! Not to mention that it's the cat. Maybe you could make an elbow before the cat, and find room for it farther down the exhaust.
So, how loud is the Insight's 1.0L without a muffler?
I was really hoping you'd get your car in a condition to limp to N.H. so you could work on it and play with it there, but I can't hold it against you for failing to complete an unprecedented engine transplant in a weekend or two.
