11-27-2009, 07:45 PM
#441 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
Got a torch? Heat 'em up, and you're gonna need new balljoints if they're that bad.
The jack method is still available at this point, if you have an old axle stub and a mallet. You should see a flat riser on the side of the ball joint taper point (on the knuckle), you can whack that good and it will temporarily deform the taper point enough to let loose on the ball joint. Or, since it's already done for, you could just put the nut back on and whack away at the head of it.
11-27-2009, 08:17 PM
#442 (permalink)
Dartmouth 2010
I've decided to go ahead and give up. If I don't, I have a slim chance of finishing but a big chance of a stressful time trying to get home. I am just too tired from school right now to put my full effort in. I will come back with a vengeance in about 2 weeks though and finish up in lovely december when I have about a month of freedom to work on it!
Anyway, I got most of the exhaust done and some other stuff, but some tasks like the knuckles seem pretty out of reach at this point. We'll see when I get back. first thing I'll do when the exhaust is on is see if I can pop some of the DX axles in and start the thing up. Time will tell.
11-27-2009, 08:43 PM
#443 (permalink)
Probably for the best if you can't give it 100%. Not the kind of project you want to screw up details on.
11-27-2009, 08:52 PM
#444 (permalink)
Dartmouth 2010
Indeedy do. That said, I think it'll be excitingly finished.
11-27-2009, 08:54 PM
#445 (permalink)
:cry: I want time to work on the 4 million projects I have!!! :cry:
Well, time, space, money, etc... I just want a perfect alignment, really.
11-27-2009, 08:58 PM
#446 (permalink)
pickup - '01 Dodge Dakota Quad Cab 4x4 Sport 90 day: 16.35 mpg (US) Focus - '16 Ford Focus SE 90 day: 31.46 mpg (US)
Priorities
Sounds like you are making progress SVO.
Probably a good decision to get back to Hangover unstressed and ready for school. Hope you find a ride back that works out.
If anyone wants to read about my thesis, I'll send you my proposal
Yeah, I would be interested, not that my opinion would be of any help. PM it.
After mid terms (if called that) you can go back and work on the project some more with a fresh mind.
11-27-2009, 09:21 PM
#447 (permalink)
Dartmouth 2010
Clearly your mind is too active for your own good
11-27-2009, 11:21 PM
#448 (permalink)
I concur.
Things should get a little easier once I'm back "in the mix", and have my own space to work on things.
11-27-2009, 11:39 PM
#449 (permalink)
Left Lane Ecodriver
Here's a question for you innovative folks.
The water pump belt I got from autozone is too big. What should I do? There are no others available.
Go buy a 370K5 (37") or 5PK935 (935mm) belt, or the nearest size that they *do* have.
Well, I'll have to poke around for that then. Also, I took a closer look at my exhaust, the S bend isn't going to happen, so I'm just gonna take off the second cat and run a pipe back. Only problem is the exhaust doesn't want to budge.
You mean you want to cut part #7 in half? But that's a $700 part! Not to mention that it's the cat. Maybe you could make an elbow before the cat, and find room for it farther down the exhaust.
So, how loud is the Insight's 1.0L without a muffler?
I was really hoping you'd get your car in a condition to limp to N.H. so you could work on it and play with it there, but I can't hold it against you for failing to complete an unprecedented engine transplant in a weekend or two.
11-28-2009, 12:42 AM
#450 (permalink)
Dartmouth 2010
Nope, didn't cut that in half. Cut something out of my CRX exhaust in half.
However, I do have a cut in half $700 cat in my garage
