Old 11-28-2009, 12:42 AM   #186 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Rick -
MSD RPM Switch installation instructions/part numbers.
Here, you can find the RPM switch installation instructions. If you look around, you'll find a how-to on making your own "pills" to select the RPM range at which the switch is closed. I'd probably look into making one that closed the switch at 1300-1500, I think.
