Old 11-29-2009, 01:43 AM   #7 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
I love that you're already planning further efficiency mods.
Ha Ha, I basjoosed my headlights and weather stripped the engine compartment yesterday. CAN'T. STOP. ECOMODDING. HELP.
If I were doing it, I would probably approach using a step-up, power supply rated at say 600 W (~45 A @13.8 VDC). It would use a current regulating circuit to tickle the voltage up and displace the inverter load. As soon as the target current from the deep storage battery was reached, hold it there.
If I knew more about electronics, I would probably agree with that approach. I will look into a current regulator and see if it's something I can handle. I was hoping for a simpler approach but I suppose I should start the new thread to describe what I hope to do.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
