Old 11-29-2009, 10:32 PM   #4 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
So GPS has the best accuracy. I use mine in several different cars though. If I calibrate the ScanGuage II using the GPS, is the SGII accurate enough that I should use that reading instead the odometer when logging fuel economy in my garage?
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
