Originally Posted by MPaulHolmes
One way to test is to check with an Ohm-meter from the solder joints that have rings around them to the ground plane. If there is a short to the ground plane, then that has to be fixed. I'll get those little pieces mailed out tomorrow or thursday. I just have to work until 8pm tomorrow.
Thanks Paul. Tried the HF Meter and I have it set at 200 Ohms. When I find ground it goes from 1 to 005-7. Is this what it is supposed to do? I am about
green as grass with electronics, Trying to learn. Appreciate the little parts. Will try to get the rest when I get the CB sorted out. Watt.
