Old 12-02-2009, 02:42 AM   #34 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Sorry, joining the party late...
That's a rule of thumb for the initial transition. If you taper gradually (ie curve), you can apparently go up to 22* with attached flow (assuming the upstream flow is clean).
Yes. The images Cd made would yield better results than the initial mockup - glad to hear those are being copied. You want an organic shape so pressure recovery is gradual, not hard corners which could trip the flow and cause early separation.
The exception is the very rear surface (what I call the transom - where the tail lights go). You can chop that off clean and have hard corners there.
Thanks for all the input.
Its about time you joined the party.lol
I need all the help I can get.
Pressure Gradient Force
The Positive Side of the Number Line
