Old 12-01-2009, 09:37 PM   #31 (permalink)
discovery's Avatar
Very nice, gives me a though to start my own boat tail. Keep up the good work
Honda Insight Parts For Sale
http://imageshack.us/g/1/10087943/
http://imageshack.us/g/1/10087939/
Bought Accord 88 LX'i on ebay.com for $380
Check out our Honda build
http://www.3geez.com/forum/showthread.php?t=67592
Also check out the Scooter we bought for $300- 92MPG
http://scootdawg.proboards.com/index...y&thread=32692
Old 12-01-2009, 10:02 PM   #32 (permalink)
90 day: 57.73 mpg (US)
Sorry, joining the party late...
Originally Posted by jedi_sol View Post
In my old kammback thread, I was told the transition should be 10* to keep attached airflow.
That's a rule of thumb for the initial transition. If you taper gradually (ie curve), you can apparently go up to 22* with attached flow (assuming the upstream flow is clean).
Also, I was told by MetroMPG that the transition from the top to the side should be rounded, which i haven't figured out yet. Otherwise (correct me if im wrong MetroMPG) it would create vortices (spelling?) in that area.
Yes. The images Cd made would yield better results than the initial mockup - glad to hear those are being copied. You want an organic shape so pressure recovery is gradual, not hard corners which could trip the flow and cause early separation.
The exception is the very rear surface (what I call the transom - where the tail lights go). You can chop that off clean and have hard corners there.
Old 12-02-2009, 02:41 AM   #33 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Thanks, its been a pain but I'm sure when its all done it will be worth it.
Pressure Gradient Force
The Positive Side of the Number Line
Old 12-02-2009, 02:42 AM   #34 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Thanks for all the input.
Its about time you joined the party.lol
I need all the help I can get.
Old 12-02-2009, 05:47 PM   #35 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
pgfpro -
Originally Posted by pgfpro View Post
Yes that was me I borrowed a hatch off a MX-3 and its way off.
I could make it work but there wouldn't be much left of the original hatch after I got done with it. LOL
That's too bad, because it looks so good from the side :
CarloSW2
American Solar Energy Society
Old 12-02-2009, 07:24 PM   #36 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Just curious about which areas of the hatch were off from the MX-3.
Unless the hatch was too wide, it seems that you could modify the C pillars and the edges of the hatch to meet.
I know that you would have to do some build up or cutting between the two components, but I'm just curious about where they don't match up.
Also, I wanted to add that the corkscrew effect in the picture that I was talking about was mainly due to the angle of the shot. It looked a lot worse than it really is now that I look at it again.
Old 12-02-2009, 07:46 PM   #37 (permalink)
sides
Heres another pic of the roof line. You can see it better from this angle. Its very slight in the transition, but mabye it needs to be more level with the roof line???
It's hard to tell without being right there looking at it but the side I can see has reflex curvature,cupping toward the inside instead of out.
The line should look like that of an ellipse,with almost zero curvature where the tail begins,then gently becoming more and more curved,the further back you go.
I don't have Mair's chart in front of me,but I believe the curvature could possess the 22-degree angle at a length equal to the height of the car ( around 50-inches.1250mm downstream ).
These curves are already cheating the air as much as possible.If you go below the minimums you'll guarantee separation with severely compromised performance.
Remember,Kamm said to follow the path to wherever you want to cut the body off,but you've got to stay on the path.
If you haven't seen the aerodynamic streamlining template,I recommend you do.It will explain the origins of the art and give you good science with which to compare your work.
Really like what you're doing!
Old 12-02-2009, 09:18 PM   #38 (permalink)
This is the template Phil is talking about. (I've learned to listen to him - he's been studying this stuff for a while now.)
Old 12-03-2009, 03:21 AM   #39 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
I found this from one of aerohead's old threads over this summer.
Someone wanna take a stab at this? I'm not sure my version is correct.
Name:	streamlining template.jpg
ID:	4909   Click image for larger version
ID:	4910   Click image for larger version
Name:	streamlining template del sol small.jpg
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 12-03-2009, 03:25 AM   #40 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Yes it was to wide. So as soon as I realized that I would have to replace the glass I gave up.
Thanks though it was a great idea!!!
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 148 08-12-2021 11:53 PM
Scion xA aero mods NeilBlanchard Aerodynamics 521 04-20-2015 11:34 PM
Red Jelly Bean Aero Mods. minic6 Aerodynamics 13 10-25-2008 12:01 AM
Aero mods for our coupes?? swoody Aerodynamics 14 09-05-2008 03:07 AM
Saturn aero mods? Heynow999 Aerodynamics 5 05-05-2008 07:44 PM
