Originally Posted by IsaacCarlson
If it is on the output I should be able to EOC right? If not then DON'T?
Check your owner's manual - it will tell you how far you can tow the vehicle with all four tires on the ground, and at what speed. Follow it when you EOC.
Don't worry about where your fluid pump is, it's not going to make a difference for the short distances you'll be coasting.
