Old 12-03-2009, 01:00 AM   #175 (permalink)
Hermie
Stickers - '91 Ford Tempo GL
Send a message via AIM to Hermie Send a message via MSN to Hermie Send a message via Yahoo to Hermie
And Frank was the one to derail it.
Madison: Obviously, no car can lift off the ground at 55 MPH. Also, that's only small highway speeds. Most multilane highways are at 65, and some freeways are listed at 70.
Unless you're one of those drivers that causes pileups behind you because you're too much of a balloon foot, for which you can be ticketed for...
Aerodynamic lift reduces the traction avaliable to the tires, and in the event of an emergency (freeway-speed swerving or hard braking), high degrees of lift can cause your tires to lose traction, making you lose control. Unless you're an idiot, you should know that.
