Old 12-04-2009, 01:43 AM   #60 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by Christ View Post
Are you running hot, or just lean?
Were there any other direct measurements you can think of that you'd need off that hatch?
I running both. Intake temps when in lean burn mode anywhere from 140*F to 190*F
Lean burn mode from 19:1 A/F ratio high load (acceleration to climbing hills) to 25:1 steady state cruising speed. I'm hoping to get it up to 30:1 in SSCS mode.
I think the measurements you said earlier in the post will get what I need?
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
Christ (12-04-2009)
