Old 12-04-2009, 03:13 PM   #19 (permalink)
darcane
darcane's Avatar
Well, the tank was still 2/3 full, but I decided to fill it up this morning just to get some preliminary numbers. No significant change in mileage. However, we've also had a cold snap (high 20°s instead of low 40°s on the last commuting fill up) this week and I've had to spend some time letting it warm up in the morning so I could see well enough to drive. I'll report more over the next couple months.
ECONORAM: I had previously seen your post and it gave me some ideas for mounting the belly pan. You may notice I'm using the same predrilled steel flat bar, which I used 1/4" spring nuts and screws to attach everything.
GoodOak: I used Corex sheet (essentially the same as Coroplast) for both panels. I picked up several sheets for about $16 per 4mm thick 4'x8' sheet from a local plastic supplier.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
