Originally Posted by jackbauer
Paul just thinking that as i'm running at 8mhz then all the timer loops in the micro are running at twice the intended delay. Will this effect things like the throttle ramp rate etc?
Jack, why did you switch from 16 to 8 KHZ micro speed? Shut-off time in the IGBT gates or else?
