Old 12-06-2009, 02:02 PM   #380 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
so you don't like the answer its not inline with your preconcieved notions so you fly off the handle?
No that would be you!!!
do you honestly thing the fact that one car uses FOUR TIMES MORE FUEL than the other is irrelevant in a hydrogen fuel discussion?
Do you understand that its gets pretty much the same MPG or even a little less then it did on gasoline!!! There no magically BTU's in Hydrogen is there!!!
do you disagree with the concept that I don't care how efficient it is but only how EXPENSIVE it is? if hydrogen is 40 times LESS efficient than gasoline but 100 times cheaper (the E in my house) well thats a win is it not? (IF your goal is to save money NOT use less energy)
Did you not read the information I gave from a Nuclear Physicist. Saying the cost to make Hydrogen off the grid is very expensive!!!
Pressure Gradient Force
The Positive Side of the Number Line
