Old 03-16-2008, 11:00 AM   #15 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by Straight-3 View Post
I may not ever even use 5th gear!
For acceleration, that probably makes sense. But you still want 5th for cruising.
Remember - a BSFC chart shows fuel consumption of a significantly LOADED engine. Under light loads (ie. level road cruising), lowest RPM is generally the most efficient:
http://metrompg.com/posts/rpm-mpg.htm
