what's to say toyota didn't fudge the numbers to make themselves look better too? like many things, the truth is probably in the middle.
You may be right. I bet the CD they give is for their base Prius but that does not justify GM's "fudge". I wouldn't let Toyota off the hook if that were the case but this was GM's story and they could have tested the base but they didn't.
I wish someone would do independent Cd tests so consumers and, more importantly, ecomodders would have consistent info. But then what would we have to debate about?
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
