Probably less likely, same with the old Mercedes concepts, etc... With a low enough Cg, I doubt tossing it would really be a problem. The other consideration when I decided to build a R-trike was that I could use the entire driveline as it was, replacing the swingarm with a rigid frame section.
Who needs rear suspension anyway?
